It’ on the way
Here is a Beta Mapping I Created.
https://www.dropbox.com/s/nm3ubwu3nd8…
See this link to if your headphone cue is not working:
Glad you got it working. It is a little tricky to get it to work and the cue volume is disproportionately loud. I have not continued working on the my mapping file; I thought they would have released one by now.
According to their website it looks like MAC now supports SR2…?
Yes! Whoever has an SR2 please plug and play and let us know!
I started the process and successfully mapped the most important buttons. I had some issues with the Jog Wheels but didn’t get much help from support. They just referred me to the manual.
Yes. I will work on it again and see if I can figure it out.
I think I have the Jog Wheels figured out. Well in vinyl mode at least. I will continue on the other buttons. There is a lot then you have all the shift operations. I will post a file once all the basic functionality is done so you can check it out.
Send an email to Jdborris@hotmail.com. I will send it to you.
It is working. I just haven’t finished it. Couple guys here are beta testing. I will be working on it for the rest of the week. I need results from testers too.
Read this post to fix headphones/cue http://help.algoriddim.com/customer/e…
if that’s the case, i wonder if it’s for Djay Pro as well as Djay Pro 2…
need to test this out…
Hey Lukas
Please add me as a user request to map sr2
Anyway you could send me the mapping ASAP??? glennBproductions@yahoo.com
Can you please share the mapping?
Many thanks to do that!
Can we please get an update on timeline? Many people are saying they need support for DDJ-SR2 - we need it BIGLY!
