Related to Change Key Sync behaviour to match CDJ-3000 I’d love a setting for Fuzzy Key Mixing, just like the CDJ’s do.
Long story short, far more keys are compatible in most cases and a maximum transposition of -/+ 2 sounds way better than exactly matching the keys of two tracks when the pitch shift is out of this range (e.g. +/- 4).
Older versions of Djay had an option to ignore Major / Minor, but this is gone too (at least, I can’t seem to find it anymore). A preference for Fuzzy Key Mixing instead of forcing an exact match would be awesome.
More background info here: Fuzzy Keymixing: The Easy New Way To Mix Anything Into Anything
