MATCH Feature needs more options !
As a new user of Djay I am still discovering many options and gimmicks within the software.
One of the cool features I find is the " MATCH " option that tries to assist you in finding the right tune to go with what you are playing at that time.
Many may argue that a Dj needs to complete his set in advance. I beg to differ as such pre-set jobs leave little or no room for spontaneous changes, due to demand from the audience or the boss ![]()
So, while Djaying I regularly see what MATCH is suggesting to play. The only downside is that you have just 2 options to pick from, either your whole library or Local files where Local means everything that’s in your iTunes/Music library.
I would welcome the option to narrow down the search to use the same listing as your library does.
So if I have a library with , for example :
Library-
- Disco
- 80s
- Floorfillers
- Techno
- Folk Songs
- Country
- Blues
- Old stuff
However if I am playing anything from, say Techno, then it would not match very well with a similar BPM and Key from Country. So you’d want MATCH to search within the " Techno " playlist.
Please have the DevTeam create or add the option to select the folder where MATCH does it’s thing, Either Full Library or Selected Playlists…( obviously with the interface to select the playlists to search in )
Hope this makes sense …
Cheers
Peter
