- Device model (PC - AMD Ryzen 2700X, 32 RAM, M2 SSD):
- Version of operating system (Windows 10. 22H2):
- Version of djay (5.2.3):
- Hardware/controllers used (Hercules Inpulse 500):
Your question:
Why don’t I see tracks in Right panel - Match tracks option?
I’ve tried both local folders on my computer and added tracks to My Collection (Playlists), but it didn’t make a difference.
I use another DJ program, DJUCED, which has the same option to select suitable tracks. Everything works fine in it. The tracks are shown.
I think it’s safe to say that djay pro 5.2 doesn’t create its own database for selecting tracks, and instead relies on the iTunes database.
It would be pretty unusual to have to install iTunes just to access tracks on Windows.
What are your thoughts on this? I’d love to hear your take on it.
P.S. I really like the program! I just have a couple of questions about how it works with metadata (meta tag) and a large local music library. I’d love to be able to make the program see all the metadata written in the file and write new metadata (meta tag) for the program to see them. That way, I can analyze tracks based on them!
