Since djay Pro 5.4 (macOS/iOS/Windows/Android), Cue Points/Loops now have two banks (1–8 and 9–16). Currently, switching between them requires two separate MIDI commands (Bank 1 and Bank 2).
It would be much more convenient to (also) have a single toggle command to switch between Bank 1 and Bank 2. Similar to existing toggles like EQ/Neural Mix or Elapsed/Remaining time.
Why this is needed:
- Saves a MIDI button (only one button needed instead of two).
- Only use one button for switching gives a more logical workflow
- Reduces the chance of confusion or mis-triggering in a live set.
- Fits the workflow better for controllers with limited assignable buttons.
Request:
Please add a “Toggle Cue/Loop Bank 1/2” MIDI command in djay’s MIDI mapping options.
If you’d like this feature too, please make sure to vote using the upper-left Vote box to show your support!
btw; this suggestion originates from this question.
