Mixon 8 v DDJ-FLX10
Hi @amattas, welcome to the Community! Please use search before creating new topics. I have merged your new topic with this existing one. Thanks!
I am using the FLX10 with my iPad Air 5th Gen.
In general It works well and I love the software.
However, the hardware/software integration is not sufficient in my opinion. It drives me crazy that it is required to tap on virtual buttons in the software instead on real buttons on the controller when you want to change the pad mode from hot cues to Fx as an example. Very cumbersome especially when you are a bit nervous in front of a big crowd (as I was last week). Further, its a shame that the controller has jog wheel screens that are not supported by the software.
Hi there, does the flx 10 have stem split mapped well and also the stem effect buttons?
Yes, this part of the hardware/software integration is working very well
Excellent. I take it the effects are software based and not pioneers? I would imagine they got them close but are they ok?
