Hello ! I actually found this question related to the old Mixtour here (djay Pro & iPad & reloop Mixtour -- Search/Seek function & Cue Points) but the topic is from 2016 and is locked. I love my Mixtour Pro, a powerhouse in such a small unit, I was wondering why when you « seek » inside the track using the knob, it only jumps 3-ish beats instead of 4. If I’m at a drop or a chorus and want to move back 8 or 16 bars to set up a cue point for instance (pretty standard use case), when I seek back eight or sixteen clicks, it ever so slightly moves so that by 16 clicks, i’m not 16 bars earlier precisely (more like 15-ish) (don’t know if I’m being clear)
I don’t know why it was set up like this instead of a nice round « 1 click = 1 bar » haha. But just a suggestion that would make life easier since it is one of the star controllers of the latest 5.2 update.
Best,
Jean
- Device model (e.g. 2020 iPad Air 4th Gen): iPad Pro M4
- Version of operating system (e.g. macOS 14.4.1): iPad OS18
- Version of djay (e.g. 5.1.2): 5.2
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): MixTour Pro
