Mixtrack Platinum FX Stems mapping
  • Device model HP zbook
  • Version of operating system *Windows 11 Pro
  • Hardware/controllers used Numark Mixtrack Platnium FX
Hi All,
can stems be assigned to the sampler pads on the Numark mixtrack Plat FX?
i have it set up like that on serato, would love to get it set up like this on here
i cant find the option to toggle it on?
any help would be appricated
Hi @Hixx_24, you can definitely do this, but it needs to be done through the MIDI Learn tool in djay. There is no setting to just swap these out like in Serato. For more details, please refer to this existing topic which should help guide you through the process.
Also, here’s a link to the MIDI Mapping Guide for Windows:
