I have a mixer with midi that is not natively supported and a pioneer cdj350. The cdj350 will not be recognized anymore after playing it together with the mixer. Are multiple midi devices an issue?
Thanks for reaching out about this. So I can provide the most accurate and helpful response to your question, could you please tell us the following:
- What device are you currently using?
- Which OS version is running on your device?
- Which djay version are you using?
- What mixer are you using?
Also, there are some existing Community threads on this topic that you may find helpful, depending on what setup you’re using. Here’s one example:
Thanks in advance for the additional information.
If it may be helpful, I’ve just installed Korg nanoKontrol in conjunction with Pioneer DDJ RX (external mixing), and it works well. I am using Djay Pro iOS on iPad Pro.
Still working on mapping, but double or more midi devices are fully supported.
