Hi @explash, thanks for answering my questions. To enable Desktop and Documents folders in iCloud Drive on macOS (including Tahoe 26), follow these steps:
Make sure you’re signed in to iCloud with the same Apple Account on all devices you want to use.
Click the Apple menu () in the top-left corner and choose System Settings.
Click your name at the top of the sidebar, then click iCloud.
Click Drive (or iCloud Drive).
Confirm that Sync this Mac is turned on.
Turn on Desktop & Documents Folders.
Click Done.
As requested earlier, Can you please capture a **Sample Process** using **Activity Monitor** on your Mac while the issue is occurring?
Please make sure that you collect the Sample Process while the issue is occurring.
Open Activity Monitor: Locate and open Activity Monitor on your Mac. Usually found in the Utilities folder within your Applications folder.
Select CPU: In Activity Monitor, ensure the CPU tab at the top is selected.
Choose djay Pro: Scroll down and locate the djay Pro App process in the CPU list.
Sample Process: Click the gear icon (Actions) in the Activity Monitor toolbar and select “Sample Process”.
Save the report: After sampling, save the generated report for submission and further analysis.
Upload the report: Upload the report to your Google Drive/Dropbox, enable sharing permissions, then share a link to the file here.
