Music randomly speeding up plus Issues
Well, this thing with sync is still coming up
I’ll just leave this here
I don’t understand why you’re pressing sync. You only have one track playing. There’s no need to sync to anything, but you have sync enabled on the left (non playing) deck and on the right deck.
I’m showing the fact, that despite only one track playing it’s still happening
Thanks for the video @Akrilovy. I’ll share it with engineering.
Hi again @Akrilovy, does this always (or more often) happen when the previous song is the one in the video on the left deck (Perdoa Coracao)? It would be good to know if this is related to a specific song. If not that, it would be great if you could identify a path of steps that you believe increase the likelihood of the issue happening. Thanks!
It is not song specific, happens with different tracks, but I’ll try my best to identify attributes or similarities for the encountered problems.
Thank you @Akrilovy, I’ll pass this info on.
So, somehow it tries to sync to deck one, even when that is not playing.
But not syncing stable manner, but in a strange way…
Would that also be the case when the dader of deck one would be down?
Yes, happens even when the fader is down.
First of all I must say that it’s clear that this is very, very problematic when you encounter it while DJing. You absolutely don’t want to experience this—it’s just embarrassing.
It also looks a lot like this issue that I entered in November last year:
Seeing you video I noticed we both experienced the same issue with Deck 1: it somehow manages to stay on ‘Play,’ even when the track has ended and the playhead is at the very end. This is rare but does happen occasionally.
When this happens, it somehow manages to ‘pull the track in Deck 2 down,’ causing awful and strange behavior in terms of steadiness, stability, and synchronization of that song.
I’m wondering if you’ve experienced this again since then, or was it a one-time occurrence? And have you found other tracks showing the same problem?
I wonder if we are getting anywhere with this. Both tracks have a fixed BPM, not a dynamic one. The anchor is set to compensate for the extra bars of silence, but when the system does that by temporarily changing the BPM of the first track, it sets the incoming track’s BPM incorrectly. I’m starting the second track, and if I don’t disable SYNC by the time the first playing track reaches that BPM-change point (which many times I forget), the error occurs. It doesn’t matter if the fader is up or down—it’s tied to the tracks being synced. So is disabling SYNC at points like this the only possible solution, or is this issue being somehow addressed?
Personally. I would move the end cue to another part of that song.
I like to mix rock music, this happens all the time.
Move the end cue, you’re problem may go away.
Here is an example.
Right deck’s end cue is where the song varies in bpm.
Look at the pitch behavior on the left deck.
If I move the end cue (teal color cue) on the right deck where the tempo is normal,
Now look at the behavior of the pitch on the left deck.
The left deck is just chill😊
