Hi
i got a ipad air 2 so bought a cable going from the usb slot into my ipad and the latter is not charging whilst using ddj-wego3.
Any recommendation on how to solve this please?
thanks so much
ChrisR
Hi @chrisr,
Thanks for sharing your recent experience, sorry to see that you’ve been experiencing this behavior.
Please let us know if @PKtheDJ’s feedback helped, and if you need further assistance please @ reply myself.
Thank you so much!
@PKtheDJ thanks for your help
@NathanielAlgo so I understand that if i get a hub my ipad will charge, but will the music flow through from the ipad to the hub to the ddj-wego3 to the speakers?
Hi @chrisr, yes, the audio signal will pass through the powered hub to your controller.
@Slak_Jaw thanks for your response. any specific hub i need to look out for or just any usb hub will do? thanks again…
You’re welcome. Just make sure you get a high quality one from a reputable manufacturer like Baseus. Make sure it has Power Delivery pass through.
@Slak_Jaw hope you are well,
just got my hub and unfortunately it doesn’t work.
The loop: Ipad => hub => ddj wego3 doesn’t work. the link between the ipad and console through the hub doesn’t work…any recommendations?
Hi @chrisr,
- Disconnect all cables and adapters from your iPad and DJ controller.
- Close djay.
- Perform a Forced Restart of your iPad (Force restart iPad - Apple Support (CA))
- After restarting, connect your powered USB hub to your iPad and confirm there is a blue peripheral icon in the top right of your iPad screen.
- Connect your original Apple charger and cable to the USB hub and confirm that your iPad is charging.
- Connect your DJ controller to the USB hub using a high-quality USB cable (ideally with dual ferrites on either end).
- Confirm that your DJ controller powers up.
- Launch djay.
- Open the djay Settings>MIDI Devices and confirm that your controller is shown under MIDI DEVICES.
- If not, scroll down to the bottom and press Rescan for MIDI Devices.
- If this doesn’t work, unplug the USB cable from your DJ controller for a second then plug it back in.
- If this doesn’t work, try a different USB cable.
