When midi mapping 4 channel stems, it’s possible to choose Volume or EQ on each stem.
When set to 4 decks, the bass and harmonics volume can not be set separately.
Hi @RobustaDK, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Please note, there is no 4 Knob Neural Mix EQ UI option in djay as the Normal EQ only uses 3 Knobs. However, there are UI modes to show 4 Channel Neural Mix Volumes. See below examples on iOS and Windows. The setup should be pretty similar on macOS. I hope that helps!
Also, there is an existing Suggestion topic to add 4 Channel NM EQs View Mode to djay if you would like to cast your vote over there:
I am using some additional hardware to midi map the stems. It seems a bit silly that I can choose the option in the mapping interface, but it does not work. No matter how the UI options work.
Thanks for the additional feedback @RobustaDK. I will share this with the devs!
