Given that we now know that the Neural Mix Crossfaders have been killed off in favour of some gimmick on a crossfader, please vote below if you would like to see them reinstated.
You can also vote for this topic using the ‘Vote’ button above, which helps to feedback to the team as well.
Agreed … shouldn’t be too hard to put them back in … most of the underlying code is there or even enable us to EQ neural mix on two decks at same time (link them). Mixing sounded WAY better with Neural Mix Crossfaders than the crossfader FX.
I like it the way it is. With Mixon 8 mapping eq can be set to neural mix or eq, plus I have pads as well like serato with effect for each stem. I also use the cross fader fx. Option to have or not to have would be best.
Hello everyone, I’m happy to report that we have brought back the Neural Mix Crossfaders. You can now access these in the NM menu while in EQ/Mixer mode.
