Neural mix latency with key-locked tempo change
I created this issue 2 years ago and been the reason why I find it difficult using Djay Pro: Neural Mix Mute/Solo Latency when Keylock is On
It’s still not fixed on mac and ios. I have latest version of Djay Pro and also testing with local music files.
Curious if there’s a plan since it’s been 2 years. For now I end up using mute fx to make the bug less obvious.
Hi @codebeast, thanks for checking in. Improving this is on the roadmap, but I can’t share more than that.
Thanks for the update @Slak_Jaw
Looking forward to the changes.
You’re welcome @codebeast
