How about an On & Off Button For Neural Mix.
So we can turn it off when we want.
Sometimes I like to Mix several accapellas one after the other.
I hate having to turn on Neural Mix for Each song.
There are a lot of Neural Mix MIDI commands that can be mapped. Which feature in particular did you want to turn On/Off?
Nueral Mix Settings turn off every time you load up a new song I want it to stay on until I want it off.
@MontyJoe to better understand you, are you saying for example:
If this is the case, then I think I can understand why someone would want this functionality. This would definitely need to be a separate option in the settings under General->SONG LOADING->Reset Neural Mix. Personally, I want the Neural Mix to always reset on song loading.
There’s a workaround you can use:
This will persist even upon Song change. Hope that helps.
That’s exactly what I’m talking about.
Thanx Joe. I don’t like using my EQ buttons for Neural Mix.
Turning off EQ reset did. Not work.
Are you adjusting your Neural Mix via EQ? This only works if you now also use the EQ instead of other ways to engage Neural Mix.
