Separate the “Reset EQ, FX, Tempo” Settings
Well I would like to expand on this suggestion and ask that Algoriddim also separate the “Reset EQ, FX, Tempo” so we can turn these all on/off individually.
Personally, I would like to have only FX and Neural Mix reset on song load and for the EQ and Tempo to maintain their settings on song load.
Hey @Slak_Jaw ,
Thank you for suggesting this. Great stuff!
I moved the post to create a separate thread for it, as this will hopefully make it easier for other users to notice and upvote/comment.
In the meantime, I’ll check with the Dev Team if we can open (or have already) an internal request. I’ll keep you posted with any updates on this.
Cheers!
Hey @Slak_Jaw ,
Hope all is well!
I am writing to share that an internal request regarding your feedback and the option to separate the Reset EQ, FX and Tempo Settings has been created.
I will gladly keep you posted with any updates on the topic.
Hope you will find this information useful. Cheers :slight_smile:
That’s great news. Thanks for the update @Cam_A
I have this option turned off but Neural Mix EQ is still reset on song load? From your original post it seems like this shouldn’t be the case, is this a new bug?
Ideally I’d like to avoid Neural Mix EQ reset, especially when I hit instant double and already have the deck set up with the stems I want running there.
