Greetings,
On my MacBook Pro, the Neural Mix stems crossfader button is not showing up?
Any assistance as to why would be greatly appreciated.
Thanks,
Anton
Hi @djantona, the Neural Mix Crossfader was removed on djay Pro 5 in favor of the new Crossfader FX.
Thanks for confirming.
You’re welcome @djantona
If you use an external controller and are ok with a bit of MIDI mapping I posted this recently.
Shows how to create your own version of the removed NM Xfaders.
Might be useful for you until (hopefully) they make a return.
Awesome…thanks for this, Sooteee!
