Neural Split waveforms keeps resetting
Hi Algoriddim team! I’m not sure if this is technically a bug or just a feature that hasn’t been implemented yet. I’m leaning new feature request, but could be wrong. Every time I open the app, I have to turn on the split waveform view, and anytime I stream from Spotify or Apple Music, where there are limitations (perhaps other services also have these limitations, but these are the only two I use. that do), it resets to one waveform, and I have to go back. I understand that certain streaming services don’t allow neural mixing, but it would be great for there to be a “default” behavior so that on app launch and whenever going back to a compatible track, my preferred waveform stem Split View is enabled. Switching back and forth from local or beatsource tracks to Spotify/Apple Music adds extra steps to fix the UI in the middle of me mixing. I wish it were easier to “stick” to the way I want, when possible.
A post was merged into an existing topic: Option to save Neural Mix settings after restart
Merged with existing topic: Option to save Neural Mix settings after restart
