New hardware from Reloop, designed in collaboration with Laidback Luke:
Just noticed this, pretty interesting for a āpocketā controller. Price is around ā¬500
That looks fantastic! They packed a lot into that small space! Just wow ⦠!!! Iām impressed. Canāt wait to get my hands on this.
Agreed! More pro build, 24 bit soundcard and USB-C.
The official case has enough space for a couple of iPhones ⦠ha ha ha!
Iām glad theyāre touting the new Cirrus Logic soundcard, will be interested to see how it sounds.
I only missing Tempo Fader and a bit of Pitchbend or something like that. But: cool Ideas at all.
āIt features four rubberized buttons for each channel to control Play / Pause, Cue, and Sync respectively, while the signature āLaidback Loopā button independently offers instant looping (In/Out/Exit) with a single control."
Yeah, tempo faders would have been nice. You could stick the Mixtour Pro between two turntables and get those back
Iāll probably use the Mixtour Pro with a Hercules Starlight to get back the jog wheels and tempo faders. Rig should still be ultra-compact.
Re: Pitch Bend
It does have a Pitch Bend feature (under the CUE/Play buttons)
Mojaxx says heāll be doing a video on this from NAMM tomorrowā¦
Thatās a big jump in price though. 100% increase!
tempo faders ? a pitch encoder itās 10 times better
Iāll be getting two possibly three.
considering replacing it with a reloop ready? RCA should not be a problem if you are using an external mixer or does it.
Iām fine with RCA. The Mixtour Pro is designed to be plugged into Pro audio and club gear - not replace it; but I think a good argument can be made for 6.35mm (1/4") jacks.
Am actually confused about that crossfader fusion statement. I had believed that any djay-compatible mixer/controller would automatically support the crossfader fx if active.
This statement appears to say the contrary!
Ya, the mixtour pro could have done well with at least balanced TRS outputs, if XLRs were too big for the footprint!
It would have also had quite a market, if it supported serato too!
That would have been nice indeed.
