New Reloop Mixtour Pro Hardware
Edited… ignore what i wrote before… WOW…
You can duplicate the midi on the left and it will run in the series of that!!! WTF… this is madness!!
THANK YOU.
Thanks again @Slak_Jaw for the screenshots.
You mentioned that it’s a custom function where you press a button and one deck will have Acapella and the other will be instrumental.
How did you set up multiple actions with just one button as such?
Like i can see how you have the same name “Note EQ” but 7 of them according to the screenshot .
or Note A#-1 is 4 in total. How to add multiple of that please?
You’re welcome @PoyTB. Yeah, the Duplicate function is the key. I explain in detail how to map this in the linked thread below:
Thomann and others in Germany have it on sale currently for EUR 398: Reloop Mixtour Pro – Musikhaus Thomann
I use an old Native Instruments x1/z1 case but with a decksaver as the top piece. It just about fits and is smaller than the new Reloop case
I received my Mixtour Por yesterday. I think it’s great. I can’t complain about the quality. Everything runs smoothly. Only some of the controls are very tight. But I suspect that’s intentional.
It’s fun in any case
The controls/knobs you refer to have stayed “tight” after 6 weeks of owning mine, love it. I like them like that. It’s been great for working blended transitions.
Received mine this week. I really, really wanted to like it - the idea having a small battle mixer together with an iPad Pro sounded so good. But I didn’t.
First, the device started ‘chirping’ after a while (near the USB ports). Switching from an Anker charger to a Ugreen helped a while. It became unresponsive from time to time, requiring a restart of either the software or the device.
Besides these difficulties, I personally did not like the layout too much:
  • There’s a large section dedicated to FX - which in my opinion should be used rarely. Too much use of FX annoys me. It’s wasted on me and I didn’t come up with a useful replacement to assign to this section.
  • The pads have no pressure point whatsoever.
  • The knobs controlling volume and balance of the headphone output are miniscule and have too much resistance for my taste. I use them a lot, I personally need them ‘handier’.
  • The headphone cue buttons are in the FX section which is non-standard, at least in my opinion.
Anyway, besides the technical flaws (might be a defective unit), those are just personal preferences. It’s not for me, I’m staying with my Denon MC 7000 (which of course is a totally different beast).
Does someone know if the original Mixtour decksaver can be used with the Pro?
Size wise, the Pro is the same, just thicker/higher. The buttons seems to be closer to the edge, though … the original case has wide indent, with a side bump for the wide Load buttons only. If the Play/loop button section is as wide, it may just not fit.
I’ve had a mini gig tonight, and used my old Mixtour. The audio quality is just not good enough. Have forgotten how much I don’t like how it sounds on a good sound system. I want to sell it and get a Pro. As I have both a case and a Decksaver for the MT, I’m thinking of selling it with the case only, keeping the cover to use with the Pro. But if it won’t fit, I better order the MTP Decksaver right away to optimise the shipping cost.
I’m pretty sure the original Decksaver does not fit the new Mixtour Pro.
It does not. It nearly does… but sadly does not…
Looks like it works pretty well in tandem with LC6000s
Nice! I’ve been considering this exact setup.
Has anybody else noticed Jumps in volume on the master output on the master output? When I turn my device master volume to 10 o’clock, the sound cuts out totally
No issues with the master volume on my Mixtour Pro. Can you please share a screenshot of your sound settings?
See video
@Nubium try switching back to the (built-in) MIDI mapping to see if that solves it. If not, seems like a hardware issue.
I’ve just tested this on my iPhone and it’s a similar problem however, the audio now disappears at 8 o’clock instead of 10 o’clock
Given that it’s happening on 2 different iOS devices, makes me think there’s a problem with the hardware itself.
  1. Can you please confirm that you are using the (built-in) MIDI mapping on both iOS devices?
  2. Can you please confirm that the Mixtour Pro is also connected to power via the second USB-C socket and that your iOS device is charging normally?
  3. Have you tried connecting to the Mixtour Pro using a different USB cable?
  4. I would also recommend closing djay and following the procedure linked below to perform a Forced Restart of your iOS device:
    a. iPhone: Force restart iPhone - Apple Support
    b. iPad: Force restart iPad - Apple Support (CA)
FYI
The iPad link doesn’t work.
I did the reset. Hi, I’m using the built-in midi map for the device and I used a different cable. I have power plugged in and the volume is disappearing at about 2 1/2 on the volume knob.
