It can maybe trickle charge, it’s 5v amp with low ampere. Wouldn’t rely on it too much, best is to try it out and see what happens. Maybe put the brightness on max on your iPad so you experience “worst case scenario”
Got a weird thing happening. I’ve been practicing at home with my iPad and no tour pro and x1. Everything working fine, including charging the iPad I get to a venue and everything worked for a little while, but now the mixtour keeps Disconnecting and the music stopping. I will admit, maybe it’s not the best quality USB hub anybody else had this thing happen?
Knowing the mixtour pro uses USB-C power delivery, I wouldn’t recommend running it of the USB hub from the X1
Yeah, I figured that out when I was first trying it out at home it wouldn’t give power to the iPad. I was using a fairly cheap powered USB, but for some reason, it just wasn’t working great. I’ll try a better quality one.
