NI Traktor X1 MK3
That’s it. I knew it was something like this but I couldn’t find it in de manual. Thanks man! Do you know why the crossfader is reversed in midi-mode?
@Slak_Jaw this should be easiest thing to map it right? why algoriddim dont do it?
Hi @hardbea7, basically this comes down to user demand. We have a small team devoted to providing support for new hardware. So, we need to prioritize based on demand and other factors. Please refer to the attached discussion for further details on how the current voting system works in relation to hardware. Thanks! Update to Our Voting System Guidelines [DJ Hardware]
its been a year non of my devices is supported, im out of hopes with djay
Hi @hardbea7, several of your controllers listed below are supported on macOS and Windows. As discussed before, the main reason some of these are not supported on iOS is because they are not USB class compliant. To the best of my knowledge, none of these controllers are supported on iOS by any other DJ software.
  1. Pioneer DDJ-1000, DDJ-800: supported on macOS and Windows
  2. Traktor S8, S4 mk3: not supported
  3. Roland 707m: not supported
  4. RANE Four: supported on macOs and Windows
  5. Numark NS4FX: supported on macOS and Windows
Sorry I meant iOS.
Will djay natively support X1MK3?
Hi @hardbea7,
This is currently on our radar, but we cannot share if/when we may support this controller at this time.
Please please natively support this controller, it should be the easiest controller to support.
Are there layers supported in the X1 MIDI mode, so that I can have the X1 MK3 able to command decks either 1+2 or 3+4 for transport, FX & NM of either pair of decks?
My main 4ch controller can switch between 1/3 + 2/4, but I wish the X1 can be mapped to also be able to switch 1/3 + 2/4 as layers, and use it as a secondary controller to either my MC7000 or a Mixtour (Pro). By default, I want to have transport & FX configured, want to be able to switch to NM mode for the selected set of decks, so I can have access to both FX and NM for the respective decks?
I figured it out myself. It will easily work through the Deck Selector and the PadMode modifiers in the MIDI mapping engine. We can implement multiple layers of control in any controller (only possible through the mapping XML now).
I’ve ordered an X1 MK3 from Thomann and will be playing with the mappings next month. In several days of mapping work, I’m planning to map it for 4 decks operation with NM/FX & Mixer control layers within DJ.
If someone already owns the X1 and wishes to get dirty with the mapping through the XMLs, the modifiers functionality is already there in Djay, so it jet needs to be put in work for the X1 so it will become a powerhouse for 4 decs control in Djay.
Here is a Draft of the Modifiers mapping HOWTO for instructions how to do it:
The play will be:
a) selecting Decks with the upper corner buttons should happens from the “General” MIDI section. It will rise states 0/1 for modifier5 & modifier6. These modifiers should then be evaluated as “conditions” for the relevant commands.
b) selecting the mode of control - EQ/FX/NM[/other layers?] will happen through the per-deck PadModeSelections, which rises modifer1-4 states for the respective decks, allowing the buttons and knobs to perform differently in the context of the selected mode with the respective “condition” strings.
c) Mixer control definitions will be straight forward through a), the deck selection
Figuring out how the modifiers work in Djay opens so many possibilities. Bad is that it’s only possible through the XML for now, and that’s a bit dirty with some risk of messing the XML structure. It will help a lot if people upvote the request to expose the modifier condition settings per MIDI command in the UI.
Based on this, I’m planning to release a powerful X1 MK3 mapping capable of 4 Decks control & Mixer/FX/NM/etc hopefully sometime in Jan/Feb, if time allows me to.
An X1 MK came to me this past weekend, and I’ve made some good use of it, through a basic multi layer mapping with Custom Shift, but without advanced modifiers for now.
The current v0.2 state seems stable & consistent and has 4 layers of control through a SHIFT & a Custom Shift. The Custom SHIFT is set at the two “REV” buttons, and both are equivalent. There are 24 unique mappable controls on the X1, so the mappings has 24*4 = 96 unique action slots:
  1. Default Button
  2. SHIFT + Button
  3. Rev + Button
  4. REV + SHIFT + Button
I’m using the X1 as supplementary controller for Decks 3/4, next to an MC7000, or a Mixtour. By default, it controls the FX in the knobs section. 4ch NM EQ & Mutes are with SHIFT+. The REV+ layers add extra features, as visible in the description table. The mixer controls are hidden behind REV+SHIFT and are not the most accessible and optimal, but are still available and usable. When we get the PadMode user space Modifiers, I can make the Mixer controls available as a top-level mode, without the need of REV+SHIFT, but for now, this is how it is.
TRAKTOR X1 MK3-v0.2-kaanou-Deck1_2.djayMidiMapping (65.8 KB)
TRAKTOR X1 MK3-v0.2-kaanou-Deck3_4.djayMidiMapping (65.8 KB)
You need to activate either the Deck1_2 or Deck3_4 mapping files in DJay. We cannot yet set custom modifiers (other than the “Controller Shift Key”) to make single mapping file for both 1/2 & 3/4, so two separate mappings are needed for now. Help is needed from Algoriddim to set modifier5/6 states to be able to switch between Deck1/3 & 2/4 with the upper area arrow (<- & ->) keys, and PadMode modifiers for the Mixer controls. I hope it won’t take them long to enable these.
I’m still testing it on iOS & MacOS but all seems consistent, and fully functional at it’s v0.2 state.
Feedback is most welcome!
wow! respect!!! i see hope!! algoriddim your turn!
Just buy a Taktor X1 MK3 , want to know if anybody have map the controller i Djay Pro.
I start doing the mapping in DJay Pro, a lots of work do it.
Thanks for your help !
Hi @DISCOMOBILE.CLUB, please use search before creating new topics. I’ve merged your new one with this existing one. Thanks!
Just bought a Trakror X1 MK3
to use with DJAY Pro and IPAD 7th
:heart: LOVE IT, GREAT TRIO.
FInish, mapping the controller in IPAD
WORTH PERFECT :smiling_face_with_three_hearts:.
Have acces of all Neutral Mix in DJay Pro etc…
Compact, easy setup, great value under 699$ cdn for the TRIO.
Sorry but TRAKTOR 2 on IPAD :face_with_peeking_eye::face_with_peeking_eye::face_with_peeking_eye:
AFTER 1 MIN OF USE, I UNINSTALL​:grimacing::grimacing::grimacing:
For some of my gigs, I use the mix tour pro And my iPad Pro. I just bought the X1 mk3. This may be a silly question, but how do I wire it all up? I can’t manage to get the X1 Midi messages coming through. The X1 Shows up on my iPad, but when I try to midi map, nothing happens.
How have you got that all wired up? I have the mixtour Pro And the X1 my 3, And my iPad is showing up the x1 in settings but No middy mapping information is getting through.
Did you press SHIFT+MODE after powering on the X1? All lights should turn blue and go in to MIDI mode on the little screen
No, I did not…., Guess I should’ve read the manual!
Can the X one give enough power to power the iPad?
