Good website or link?
Iād start with the Apple website.
Even Apple donāt sell the 30-pin-to-Lightning adapters these days. I had to go to eBay to find one for sale. Getting the genuine article was the secret to getting everything working again with my Numark iDjayPro controller and third generation iPad running djay Pro. Itās flawless, well over a decade after the hardware came out.
Donāt forget to go into the djay Pro app settings through the yellow/white button at the top of the screen, choose Audio Devices and enable pre-cueing per my screenshot below. Until you do that, the pre-fade listen (PFL) wonāt work on the Numark hardware, and your headphones will only output the Master audio and not the Cue audio. I was ready to recycle the controller until I found this support thread and somebody mentioned this point.
Welcome to the Community @DylanO! Thanks for sharing this.
Hi everyone
Just to say you that really work
I tried with iPad 6th gen + true apple adapter 30pin to lightning(that I buy on eBay) and my old idj pro.
So I can replay on my renew setting !! ![]()
Thank you DylanO for you sharing : it help me a lot
Thatās great to hear. Thanks for sharing @1ted
Alguien ha sido valiente y ha hecho la conversión de 30 pines a usb para que la laptop detecte en modo MIDI y mapear con vdj o Serato?
Has anyone been brave enough to convert the 30-pin to USB so that the laptop can detect it in MIDI mode and map it with VDJ or Serato?
