Hey, my Numark Mixtrack Pro Fx comes with 8 performance pads, for which only the upper row is currently usable for each mode.
@erikdepeerik already showed the overall problem in this discussion for the Numark Mixtrack Platinum Fx.
As the documentation of the official software Serato DJ Pro shows, the use of all 8 performance pads per mode should be possible for the Pro Fx aswell. I would love to see the support.
Hi @matze.ema,
Thanks for pointing this out to us. I’ve forwarded this request to our developers and they’ll look into this as soon as possible. We kindly ask for your patience while they do so. Thanks for your understanding.
Let me know if you have any further questions.
Cheers, G
Windows 11
5.6.5
Hi @StormeNet, I have reopened this old topic and merged your new one with it. I have confirmed with engineering. This is currently a limitation of this hardware when used with djay.
Djay
Windows setup guide: 2× XDJ-1000MK2 + DJM-900NXS2 with djay
Hi @Lilian_Mercy, welcome to the Community! Can you please clarify or rephrase your comment?
