As a user I want my filter selections to be persistent for all in the source. If I set a bpm range or pick a title in a playlist and go to another playlist, I want those filters to be persistent. Currently they are always reset.
Steps:
Select a playlist
Set filter - bpm to 110-128
Switch to another playlist (in a different folder).
Select filter. Bpm is reset to default 110-120
Go back to original playlist and all filter options have been reset.
I appreciate you including the steps to recreate your current dilemma as it will help us in getting a better understanding of how to implement a change like this to djay.
I will pass this along to our dev team for further review and update this thread with any additional information that we receive on this matter.
When we set a filter in the playlist it should apply everywhere so we can mix based on what we set from our entire library. Having a filter just for 1 playlist is kind of pointless.
I find it extremely frustrating having set a filter for BPM and key in the filter section for my current playlist only for it to be reset to default (110-120 and key of C) when I switch playlists.
The whole idea is to find songs which match across genres/playlists and this is an essential function. Otherwise may as well just sort the current playlist by BPM.
