You’re welcome @JP369. Please note that for hardware to work with iOS devices, it needs to be USB Class Compliant. This basically means it needs to function without the installation of drivers because iOS does not support driver installation. This needs to be addressed on the hardware manufacturers side of things and is beyond our control to support. I hope that helps!
Yeah sorry about that @JP369, I meant that the CDJ3000s are not supported on iOS. Yes, the DJM-S11 is supported on both macOS and iOS, but NOT the waveform display on either OS. I can see how that note is a bit confusing. It means that you need to install the latest DJM-S11 firmware for the mixer to work on iOS. This has nothing to do with screen support. The screen is NOT supported on either macOS or iOS. Please note that the hardware manufacturer needs to unlock access to their screens before we can add support for them in djay. We have reached out to the manufacturer requesting this, but it will help to expedite the process if djay users like yourself also contact the manufacturer and express their interest in having screens unlocked for Algoriddim djay.
How exactly are you connecting the DJM-S11 to your iPhone? Are you using your original Apple USB cable? Are you using a USB hub or any adapters? Please share some photos if possible. Thanks!
Thank you, now all make sense to me..
I will definitely contact Pioneer and express their interest in having screens unlocked for Algoriddim djay. The more, the merrier.
Those two images reflect my configuration (except for tar deck connection, I use the CDJ/CONTROLLER USB ports instead of the Line/RCA as indicated in the picture).
Anyway, those screenshots are about a laptop configuration, we are talking about iOS configuration here.
Again, it works perfectly with Mac OS but not in iOS.
Hi @JP369, I shared that second screenshot to ensure that you have the USB A/B dial on the top of the unit set to the corresponding USB port on the back of your unit. Can you please confirm that is in fact the case?
You’re welcome @JP369. So did adjusting that USB A/B dial solve your connection issue? If not, can you please answer my earlier questions so I can help you troubleshoot this further?
So the DJM-S11 is connecting and recognized by djay when using iOS? The CDJs will not connect or be as noted above.
If the mixer is not working on iOS please answer the following from earlier:
The mixer seems to be working correctly, but I can only tell you by what I see, since I can not hear any sound coming out of it.
I am using the same cable that I use to connect the laptop, that is the cable that I got with the mixer. (please see attachment). No USB Hub involved in my configuration.
Thank you!
Hi @JP369, I think that white USB-C adapter in your picture could be the issue. I’ve had many issues with these adapters in the past - especially with iOS devices. I highly recommend that you eliminate that adapter and use a high quality USB-C to B cable like the ones made DJ TechTools instead.
