I just bought a Pioneer DDJ-SB2, knowing it is supported by Djay Pro. However I’m having second thoughts about the Pioneer DDJ-RB that is same price, it has got some more buttons (dedicated que / play buttons) and seems to be slightly superior overall in my opinion.
I can still swap the SB2 for the RB, but my main question is: Is there a midi mapping out there for Djay pro ? It is currently not listed on the website, but this controller is almost identical to the DDJ-SB2 that is natively supported.
So has anyone tried modifying the SB2 mapping for use with this controller ?
I know you can make a mapping yourself but if basic stuff as channel leds is not working it can be a major pain.
Hi, I need your help because I have to choose between DDJ-SB2 or DDJ-RB. I would prefer the RB but because the lack of djay native support the SB2 is the only option. Is file from @Jared is almost the same as so called: “native support”? What is the difference between a good MIDI map file and native support? Can I buy the RB with no problem? Or SB2 with native support have more advantages?
Thanks! This was the push for me to get the software! I tried the demo mode and the DDJ-RB and the DDJ-SP1 work like a charm… Better than the native Rekordbox software I might add. If I change function of one of the decks pas modes they don’t both go there. This means I can use Sampler on the SP1 and hot cues on the RB or the other way around. Rekordbox switches both devices.
Just bought a DDJ-RB, and am feeling pretty frustrated that its not automatically compatible with Djay Pro. Just feels a little lazy not to map the all of the few Pioneer controllers that exist. Please speed up the process Algoriddim - everything else works brilliantly!
Goodmorning everyone. I also do a few days ago ’ I bought a Pioneer DDJ - RB as a forklift. It would be nice to have in the next update the native mapping for this controller .
please note that the DDJ RB is not supported natively. You could change the midi mapping of the SB 1/2 by sending us your RB mapping via mail.
But as we don’t have the controller at our office we can not guarantee a fully working midi mapping, this depends on if the SB 1/2 is sending the same midi signals (and channel led signals) for the same buttons like the RB.
yes changing the LED meter is not possible via the midi learn feature. Please contact us if you need help with the mapping, we will figure something out if it is not working.
