Has anyone been able to configure de browser selector for the music library? I have configured all the basics, but I can’t use the rotary selector to browse and select the tracks.
Do you have any idea why? This is my midi mapping, it is based on one I found here but I made a few corrections:
https://drive.google.com/file/d/1xC4i…
Thank you guys!
Can we get something about when this update is coming?
Sharing MIDI mappings
You can share and exchange your custom MIDI mappings with other djay users by sending the respective mapping file:
To share a mapping file:
Select “Edit Configurations…” from the “MIDI Configuration” menu at the top of the MIDI configuration window.
Select the configuration you want to share from the list.
Select “Show in Finder” from the “Options” menu.
From there, you can e.g. send the mapping file via email or save it on a USB stick.
To install a mapping file, simply double-click the file in the Finder.
Come on guys, I have a gig on 20th of may and I wanna use my sb3 controller!
Some problems over here Matthew. Can you post the midimapping,
Ok then I think my mapping is the same then yours. My major problem is the master cue.
If serato had spotify integration it was the end of Algoriddim! If the update doesn’t come quickle I’m gone!
if that is true, bye bye algoriddim!
Can you tell me how Larry? By email or messenger?
Somebody has problems too with djaypro. Can’t get connection with spotify and the program still crashes. Never happened before???
Its been 2 months and still no Update.As a paying costumer we have the right to know about the updates and time framed. So please lets us know about the update
I Just received a very rude comment from algorridim support. I can Honestly tell you all that i new moved away from DJAY pro and to serato now. So i wish you all luck, Please dont wait for the update that it might take up to 4 months beacause there are a few new controllers coming up and i think they are waiting fro those to come out so they can map all together and have one update only. Serato is awesome please try it they have a serato lite version and you can do a lot with DDJ-SB3
I just found out that the So long awaited update for Djay Pro will be release on October, After the new Macbooks go on sale.
This means is not going to be release with in the next few months. Serato DJ is 50% off.
As consumers we have the right to ask for support when we buy the software.
Hey Matthew I appreciate your input but you also need to be respectful to other peoples opinions and complaints.For you this might no be a big deal but for others maybe this is their income. Part of buying from a seller is also trusting them that they will take care of you in any support. DDJ-SB3 was release almost three months ago and still no update, as a consumer is frustrating therefore we have the right to ask and complaint if our demand is not being met on time.If the software we bought was free then I agree with you we should not be whining about it. So Please be respectful to others opinion and complaints because they have the right as a buyer and so do I.
