Hi all ![]()
Is it possible to midi map the following to my S9
Library expand (tracklist pops up when scrolling)
Looper enable
Couldnt find the functions on the mixer or midi menu but may have missed it !
Hi all ![]()
Looper enable
Hi @JEM357,
So long as your hardware is class compliant and MIDI capable then it can most likely be used with djay.
Additionally we do have a community driven list of available MIDI actions that may be helpful to you which I will link below.
Have a nice day!
