Pitch Faders - Strong sound degradation
MacBook Pro 15-inch, 2017 Ventura
Macbook Air M2 - Ventura
Problem of strong degradation of the sound reproduced when moving the Pitch slider through 0. With and without controller
How to reproduce the issue:
Master Tempo Inserted and Key at 0 - Moves the Pitch cursor through zero.
No problem without Master Tempo
No problem with Master Tempo Entered with a higher or lower pitch Key.
Hi @CorradJ, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Can you please also try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Hi, all
Device Model: MacBook Pro 2017 15-inch - Macbook Air M2 - I-Pad 2017
Version of operating system: Mac: Ventura 13.6.6. - Ipad: iPadOS ultima 2017
Version of djay: (Macbook Pro): 5.1.6 - (Macbook Air m2): 5.0.3
Hardware/controllers used DDJ1000 only on MacboockPro , but the problem exists with or without controller
Problem of strong degradation of the sound reproduced when moving the Pitch slider through zero. With and without controller
The problem is evident and generalized on different devices and versions of Djay, also verified with Reckordbox, same songs, no noise when the cursor passes over zero.
It’s clear that you have to mix using the slider Pitch to notice this no Sync… Master Tempo inserted, and default key
To hear well, try songs with long sounds such as keyboards or voices, songs with just drums and rhythm are not noticeable…
Master Tempo Inserted and Key at default - Moves the Pitch cursor through zero.
Hi @CorradJ, thanks for the additional details. I’ve never heard of an issue like this before. It would be very helpful if could you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions , then share a link to the video here? Then I can forward this to our engineering team to see if they can reproduce the issue. Thanks!
I’ve observed the same audio glitches when moving the pitch slider through zero. Running DJ Pro 5.1.6 on Mac M1 (Native).
I generated a 440Hz tone file in Audacity for clarity in this example : https://youtu.be/TlCUgyUVO_E
Note: moving pitch slider but staying within positive or negative range shows negligible artefacts. However moving through the zero position exhibits obvious aberrations.
Thanks for the video @Rob_Grimes. This really helps to clarify the issue. I have forwarded everything to the engineering team for further review. I’ll report back when I have news.
Thanks for trying and posting a video. As I wrote, the noises can be heard with the Master Tempo inserted, while I don’t hear any noises with the Master Tempo deactivated or with the Master Tempo inserted but changing the key (Key of the Song) + or - indifferent
Hi, Add for the engineers all the devices on which I have tested in addition to Rob_Grimes’ Macbook m1, and which has been doing so since at least version 5.0.3 on MacOs Ventura and on the latest version of IpadOs: mine is 2017
Version of operating system : Mac: Ventura 13.6.6. - Ipad: iPadOS latest 2017
Version of djay : (Macbook Pro): 5.1.6 - (Macbook Air m2): 5.0.3
Thank you
Thanks for the additional information @CorradJ. I’ve forwarded this to the team.
Hi, nothing has changed with version 5.1.7… But is the problem so obvious that no one notices? I do evenings and when I mix songs with melodies and synth carpets you can hear a lot
Hi @CorradJ, yes the engineering team is still working on this one. Thanks for the follow up.
Hi, With version 5.2.2 still same problem, every evening I do it is evident. Can someone from the community try? Just move the Pitch up and down passing zero with master tempo inserted, if there are melodies the degradation is very evident, I repeat it only does it with the master tempo inserted and passing on zero.
Yes I still experience this as a clearly audible glitch any time I pass the pitch fader through zero.
Thanks, also for the previous post.
Thanks for continuing to push this one @CorradJ. I sent a follow up to the dev team and will report back when I have news.
Hi, even with the latest update the same problem, I think they just don’t want to solve this problem… Apparently no one mixes anymore, only sync
Hi @CorradJ, thanks for continuing to push this one. Our engineering and development teams are still actively working on this, but it’s a performance/quality trade off. Please understand that this is a more complex issue to address than it may seem on the surface.
There are numerous features and improvements that our teams are working on in parallel to ongoing releases. So, if a feature/fix/improvement is not part of an update it does not mean we are not actively working on it. Some things take more time than others and require more extensive testing. Rest assured that every piece of feedback makes it to our teams and we take them all seriously. Thanks for understanding!
Is there anything new?
Hi @CorradJ, thanks for checking in. I followed up with our engineering team and they are still working on this. I’ll share news here when I have it. Thanks again!
Hi! It’s absurd that a bug like this is not taken into consideration. Yet it does it both from Mac and I-Pad with or without controllers. Reinstalling etc… Have the technicians tried? Have they realized what happened? Or do they say only 1 reports it? With Rekordbox obviously it doesn’t do it…
