This device seems to allow spotify songs to be loaded offline. Maybe Algoriddim can come to a similar arrangement for their software?
GOOD BUT HELP ME
GOOD KEEP IT UP AND HELP ME
I understand why the donât make it offline. Spotify doesnât want that. And if you realy want you have to pay much moreâŚ
If you want to listen to Spotify offline, all you need to convert to mp3 format, here I suggest TuneFab Spotify Music Converter for it not only convert Spotify to mp3 but also to FLAC and other formats.
Tank you is that working
I agree with the other guys here, plz integrate Spotify offline mode in the Djay Pro.
Its a pain in the a** when you have bad internetconnection / non internet.
Can Ět you integrated it so that Djay Pro looks at the âoffline/downladed tracksâ directly in spotify
I truly think this addition would make Djay Pro the absolute best DJ solution available.
It is hard to let Spotify Music offline playing until you have some tools for removing DRM or transferring your Spotify Music format to popularized music format, like mp3. Hence, I suggest a tool, say, TuneFab Spotify Music Converter. Try it!
It just my experience with this converter, it did works!
+1 for offline spotify
djay pro is the best app ever, at the beginning I thought it was expensive but after seeing its integration with spotify I loved it.
I learnt about the offiline issue the bad way, I was in a gig with a free wifi, and suddenly after 1 hour playing the songs didnt load, the wifi was having problems, but as a Professional I have my own mp3 also, and I also have a lot.
I am also a software developer and I understand that some SDK or API have some restrictions, I support the company on this.
People that dont have mp3 files for offline playing and are blaming algoriddm, are just losers! as simple as that, they have no idea about development, no idea about technical limitations, and have no idea about doing offline purchases of MP3 at beatport?
Keep up the good work!
well, for those professional DJS, they should buy the tracks from beatport or other source, if they are proffesionals, they get paid to play gigs, they have the money to buy tracks, period., I sometimes buy tracks, I havent seen the first professional BIG dj with djaypro and using spotify on a big gig. Still it would be a nice feature, but not required for big professionals on the field. Most of the tracks in spotify are short radio edits and not extended mixes, which make most EDM tracks useless.
The best solution is the ability to save/download tracks with DRM. Next time you are connected to internet, all the stream counts are uploaded and the appropriate parties are paid for the streams. This feature is about reliability for me. I often DJ in locations that have poor internet connection and it makes the software quite unreliable to use. Every gig it will cut out due to reception issues, itâs just a matter of time. I have to have another audio source on loop to quickly switch when it happens. That said, I love having the ability to play any song on Spotify and even discover music during a gig. Great product.
Spotify app has to provide APIs to acces offline data so that security is not compromised
So, Warren, howâs it going?
If sand boxing is the problem mb work with Spotify to get some end points that make you able to download a playlist in your own sand box with all security and credentials features for 1 month or one week so you will able to mix with local Spotify playlist.
Kind regards.
gooood
Here I would share my experience about using [Spotify music converter](https://www.tuneskit.com/music-converter-for-spotify-win.html
). I used to subscribe to Premium Plan on Spotify but I found that I cannot play Spotify music on another player even though I have downloaded these tracks. Then I choose to find a solution and then knew Spotify converter. I use it to download Spotify music and [convert Spotify to mp3]([2021 Latest] 12 Paid/Free Ways to Convert Spotify to MP3
). Then I can listen to Spotify track anywhere. Itâs cool and amazing.
