MacBook Pro M4 Pro, MacOS Sequoia 15.4.1, Djay Pro 5.3.2, Rane Performer
My question is related to the previewing from the library. According to the manual, if I click on the “play” icon from the library the sound should be sent to my headphones:
What really happens is that the sound is also sent to the main output. Please notice that the pre-cue is properly sent and doesn’t affect the main output, but from the library view it’s not possible to use this feature.
On my sound settings everything seems fine:
What am I doing wrong?
Many thanks in advance for your support.
