Get an iPad?
Couldn’t resist. Sorry (not Sorry):
algoriddim puts significantly more time into the Apple orchard of machines. They may or may not have a solution for you now or sometime.
Thank you for sharing what you have experienced with your Google pixel slate and djay.
Since this particular model was discontinued in 2019 by Google, I would recommend double-checking if the Android OS you’re currently running properly supports djay and Tidal.
I’d also add that the TIDAL app works fine too… It seems that the DJAY app is not listening for a response from Chrome when it jumps out to the browser for sign in confirmation.
