Problems Sorting Music in DJpro
How do I get the order of my playlist to emulate the manual order of my iTunes playlists and can I add different headings on my DJpro playlists like date added or manual numbered order heading in order to sort my playlist like I do in iTunes?
If I select alphabetic order I can’t get it to return to the Original sort I imported from my iTunes. This is on my new Macbook pro with 10.11.5 El Capitan.
Thanks,
Hugh
Hi Hugh,
clicking on a sort column works as follows:
  1. descending
  2. ascending
  3. order by iTunes
Great that works,
Thank-you
