Hi
I use iTunes and the iTunes Match service to sync my local iTunes library to my IOS devices. Can the DJAY Match feature be expanded to work on local files on the device as well. I see it’s available for streaming services, which I don’t subscribe to. I’m assume it’s using BPM/Key detection to make suggestions. Since you scan the entire library in the DJAY app, does the app not already have the data to make suggestions, the same way Traktor on IOS and Virtual DJ on Windows have been doing for years?
As libraries expand, getting a bit of AI help wouldn’t hurt ![]()
