R-Click "remove from library" option
when you right click on a track in a playlist, you are given the option to remove from playlist, but not from library, which you often want to do. this option does appear if you right click a track found in the ‘music’ playlist, ie your entrire collection. but it should always be available
“I came here to vote. However, kindly edit the suggestion to include:
Add the option: “Delete to trash bin”
Add keyboard shortcuts
Del = deletes from playlist
Cmd+Del = deletes from library
Shift+Cmd+Del = deletes from finder into trash bin”
^seconded also
Voted. I would also like the ability to delete multiple selected tracks at once
Thanks for the suggestion! I’ll share this with the devs for consideration.
Also, there is an existing related topic to this:
This is one of those suggestions that you know you need, but you just get used to adapting to the current workflow… so now is definitely the time to leave my vote. Great suggestion!
:ok_hand: this would be a welcome addition
Thanks for the input @Kevnice and @Albert_Maro
Adding my voice here for More traction!
Thanks @Armigo
Yeah this is definitely needed. It makes life so much easier when you can manage your hard drive from the app itself.
Thanks for the input @DJRemixDetroit
