Rane 12 mk2’s with Reloop RMX-95.
All four deck selection lights up when loading tracks. Another user noticed that it had something to do with the sync but I haven’t seen if there was a solution.
Same thing here:
Same thing here:
So I’ve been mixing for a few hours. I switched the decks to cue mode instead of having it on the needle search function and haven’t had the issue yet. When I switched back to needle search mode, glitch began again.
Hi @DJ_A_Diffrance, can you please record and share a short video that I can pass onto our hardware team? Thanks!
In my experience the buttons only stick in needle search mode. I mistakenly said cue mode at the end. I have to select deck 4, then deck 2 again. Then, when I load another song, all the decks light up again in needle search mode. Works perfectly in cue mode.
Thanks for the video @DJ_A_Diffrance - this is very helpful. I’ll share this with our hardware team to see if they have any suggestions.
Hi again @DJ_A_Diffrance, engineering has identified the issue and is working on a fix for an upcoming release (likely 5.3.2). Thanks!
Great!
You guys are the greatest!
You’re welcome @DJ_A_Diffrance. Thanks for the positive feedback!
