Thanks for creating a new thread about this issue.
I wasn’t aware that you reported this issue on one of the other threads. It’s better to create new threads for each bug that you find, even though it’s the same controller. That way we won’t miss anything
The videos look very cool and clear from that perspective.
This bug is funky! I’ve reported it to our developers and they’ll have a look at it as soon as possible.
As always, I’ll keep you posted here with any updates. I’m sure that very soon this controller will work perfectly with djay!
@Guillermo thanks mate, your support has been superb. I’ll be sure to create a new thread for anything else. If you need anything else regarding this issue please don’t hesitate to ask
Yes please let us know how you went…I haven’t seen much difference with the new update, the same issues are still happening for me although the crashing has all but disappeared…
If I let my ipad screen go to locked mode, I need to reset the app and switch the Rane One on/off again otherwise it glitches…
Have you noticed this as well?
Let us know how this new update works for you. We believe the backspin issue has been solved, however, it would be great if you could confirm this Thanks in advance for your collaboration!
I set my iPad to never screen lock. Occasionally I manually lock it while juggling so not to get into a habit if staring at the wave forms. Doesn’t seem to be a problem for me mate.
@Guillermo certainly appears that you’ve fixed the back spin issue! It feels so solid when executing fast juggles now! Great work, thank you for addressing this
