*NOTE: Please use
hi, does anyone have a midi mapping for Rane one
What do you want it to do that it doesn’t already?
to use it on Djay Pro 2 but I need a midi mapping for it to work
It works natively without the need for mapping but a few of us have modified the existing map to suit our personal needs
Here is a link to one of mine but I have since modified that particular map as well.
I have to add that this map is for use with the iPad, not sure if it would work with mac, Windows, Android or iPhone.
ok ill try it out.
thanks
