RB Imported Hot Cues only Green and Occasionally Missing Hot Cue A
  • Device model (e.g. 2020 iPad Air 4th Gen): MacBook Pro
  • Version of operating system (e.g. macOS 14.4.1): 14.7.8
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): XDJ AZ
  • Hardware firmware version (e.g. 1.0.1): 1.2.4
Video of both bugs: https://www.loom.com/share/d45cbea0d85f41d7a3a2c181a27a38c8
2 issues:
Playing from RB playlist into Djay Pro.
  1. Hot Cue A is missing occasionally.
  2. All hot cues are green while in RB they are multicolored.
  1. Drag songs into RB playlist and analyze with hot cues.
  2. Open Djay Pro and look at the playlist
  3. Issues are there.
C) EXPECTED RESULTS:
  1. Hot cue A is imported always
  2. Colors are the same across RB and Djay Pro.
D) ACTUAL RESULTS:
Neither.
Thank you!
2 posts were merged into an existing topic: First 3 cue points missing - Onelibrary
Merged with existing topic: First 3 cue points missing - Onelibrary
