Yes that’s right. I have both mapped to same knob.
@Slak_Jaw hey man. On your instant effects layout you have instant effects for normal use and for stems. Can you get both?
@Dysfunk_DJ you have to manually edit them as needed. Currently there’s no way to MIDI map the Instant FX Selection.
Yeah I thought so. Your map image confused me as bottom row you have 2 options for each pad.
Thanks for midi mapping , gonna be buying Reloop 8 soon , I used to use rekordbox but I prefer using djay pro now especially after djay pro 5 update.
Mixon 8 is defo the best djay pro controller right now. I would say anyway.
You’re welcome @Ellisparty
Hi all, Sorry if I missed this, but how do you access the neural mix on the EQs knobs on Mixon 8.
I tried Shift + tab nothing happens. Similar to like on Buddy and the new Mixtour Pro.
On my mapping it’s Shift + Headphone Cue. Not sure what it is in the built-in mapping.
That’s what I was trying, shift + headphone cue (tap). What is the default setting? I didn’t see it in the manual. Updated firmware as well.
Is there a ‘Transition Now’ button, that you can also toggle through on crossfade fusion on Mixon 8.
Why would you keep so many controllers just curious ![]()
As well, Shift + FX 1, 2, 3 does nothing.
Shift plus mode I believe it is
Yes , shift and tap , works on mine
Not working on mine and other Shift functions
Did you load a different mapping ?
No, I have not loaded any mappings. How do you load mappings? Doesn’t it already have a default mapping already set?
Yes, it’s just plug and play. But it is possible to edit a mapping and that’s why I asked if you loaded a new one I can’t give any more help sorry.
I like the way it is, however, some of the default mappings are not functional in my controller. I have not mapped anything on this controller. Thanks for the input.
Figured out: Shift + Tap(on Fx UNIT 1 or FX UNIT 2)
NOT SHIFT + Cue(Tap)
What’s the Cue(Tap) for then?
