I use Reloop Mixtour with a Samsung phone. Everything works well, but it doesn’t charge it while playing.
Is the charging function only possible for iOS?
Thank you.
Thank you.
Hey…I don’t know the answer, but I bought a Mixtour last week and if I it was connected tO my iPad it wasn’t working. I connect it to the laptop, took it off, connect it to the iPad, suddenly it worked.
Do you power the phone with a power bank? This is definitely something what is necessary on iOS and I could imagine that you have to do the same with android, because the device has not enough power for the Mixtour from itself.
hi
i think charging feature only works with iOS if you connect it using the lightning cable that is included with the mixtour
regards
