Device model: iPhone 12 Pro
Version of operating system: iOS 18.3.2
Version of djay: 5.2.10
Hardware/controllers used: Reloop Mixtour Pro
Hello. ![]()
I would be so grateful if you could tell me how to disable the crossfader?
Hello. ![]()
Hi @Zirrex, currently there is no direct setting within djay to disable the crossfader. Unfortunately, the hardware itself also does not have any crossfader assign switches either. However, there are a couple of options which should help.
If you navigate to the djay Settings>MIDI Devices>SCRATCH SETTINGS you can enable Crossfader Cutting Mode. This basically turns the hardware Crossfader into and On/Off switch so it will be 100% On unless it is all the way to the Left or all the way to the Right.
You can make an edit of the Mixtour Pro MIDI Mapping and delete the Crossfader in the mapping.
a. This is easily done by first Duplicating the (built-in) MIDI mapping.
b. Next move the Crossfader on your Mixtour Pro.
c. Then touch and Slide Left on the MIDI Command to reveal Delete.
d. Finally Save you new MIDI Mapping.
There is also the following Suggestion Topic if you’d like to vote for this feature: Disabling the Crossfader
