Reverse Looping - is it possible?
Hey there. I’m a beginner with current setup: numark mixtrack 3 and djay Pro as software. I want to be able to go to a cue point and loop it backwards instead of forwards from the cue point. Is this possible on the Numark or Djay pro? This would save me time, and be able to drop a beat. Thanks in advance!
Hey there,
thank you for your post.
This is not possible, but I am sure that you will manage to set set a hot cue + loop before the drop.
Cheers,Lukas E.
