Scratch Mode as default FLX6
Hey,
Was just wondering: is there any way to set the default for the FLX6 as vinyl mode? I’ve had a look through the settings + midi mapping but had no luck. Sometimes when i load a track it defaults back to pitch bend mode on the jogwheels. I wouldn’t mind if it was just 1 button to change to scratch mode, but I have to press Shift + scratch button to change it.
Hi @Intra,
Thanks for posting for the first time to the community!
By using the shift button on the controller the FLX6 puts itself into a special internal mode that is per the design of the controller and unfortunately we can not change it’s behavior.
Regardless, I will pass this along to our dev team to see if there can be some sort of workaround made in the future!
