Search Usability
I have 2 suggestions on Search button:
  1. When I use Search My Collection button and type anything, it will be much more comfortable and faster to find something if all the results there will be sorted by BPM for default because the results are shown in small column when I play my set
  2. When I use Search My Playlist button, it will be much more comfortable if I find the song, tap on it (for example #480) and close Search button, so the cursor position will be saved on that position, sometimes I need to play songs near that song in the playlist, and now I need to manually find it the playlist
3 posts were merged into an existing topic: Make “sort by BPM” option sticky so it doesn’t reset with every search
Merged with existing topic: Make "sort by BPM" option sticky so it doesn't reset with every search
