Show your DJ setup
Just realised that there is no picture thread in this forum where you can show your gear.
Let’s see if it something that catches on.
Here is my minimal setup.
Windows laptop with Reloop Mixtour Pro with a iRig Stream sound card and Reloop Hub Stand. The furniture is a Ikea Kallax, light coloured wood.
Thanks for sharing @djfredhaze
The topic below showcases some portable DJ setups:
Here’s one of my many configurations. Yes, I’m a bit of a collector and gear junky :squinting_face_with_tongue:
Here is mine, Denon Prime Go,very portable and for small events hooked up to pair of JBL Eon One speakers, completely wireless with no lag/delay at all using Sennheiser receiver/transmitter
Looks great @maurizio_T. I’m guessing that Sennheiser uses RF like SKAA?
Yes it uses RF,
It works perfectly from quite a distance as well as through walls..
I tried it from upstairs to downstairs as well and it worked fine..
I have gone a bit over kill using 3 seperate transmitters,
One for the Left master out, one for the Right Master out and one for both left and right Booth output..
All three transmitters fit within the Denon Prime go flightcase
hey @Slak_Jaw, we share the same ipad cover :slight_smile: which controller is that? Vestax VCI-400?
Nice @jefuqs! Yeah that’s an original Vestax VCI-400 (Ean Golden Edition). Still one of the best small form factor 4-channel controllers ever made IMO.
Fun thread!
MacBook Pro, Mixtour Pro. The LPD8 is a recent addition–kind of an inexpensive way to experiment with mapping some controls outside of the Mixtour.
ohh Boy, it seems you can control the bloodsugar too :))
neat and old-school
Nice! Thanks for sharing @ranchnet and @DJ-Z.
Spinning platters vs CDJs - If I would have to choose, I would take the spinning ones but I do like to use them both. With their specific pros & cons.
One of my set up. I have 4 set up. rane12+elite, rane one, a &H 4d and A&H db4 all djay based with ipad
Nice! Thanks for sharing @Selectah-X and @carletto_dj
djay pro - technics 1200 mkII - traktor kontrol S5 - traktor kontrol f1 (4 fader stems)
Technics for scratch with djay dvs vinyl
S5 in midi mode, no vu meters working, just assigned channel volume level to the vu meters.
S5 displays just displaying blocks with info on what the pads and knobs are assigned to.
F1 most enjoyable because of the tactile feeling of the 4 faders for 4 stems.
(Photo is a frame from a video)
Hi :waving_hand:t4:, I really like the simplicity of your setup. Doesn’t take up a lot of room and seems to be relaxing :smiling_face_with_sunglasses:! Thanks for sharing
Question :man_raising_hand:t4:, how do you like the Reloop Hub Stand ??
Nice Setup keepin’ it Old Skool
:headphone::smiling_face_with_sunglasses:
