- Device model (e.g. 2020 iPad Air 4th Gen): 2023 MacBook Air with 8 GB memory
- Version of operating system (e.g. macOS 14.4.1): MacOS 15.3
- Version of djay (e.g. 5.1.2): 5.2.6
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Pioneer DDJ FLX4
Your question:
When I adjust the tempo of a playing song, I sometimes hear slight (very short) blips/glitches in the audio (I’m using an external audio recorder and I hear it in the output). I don’t believe it happens every time, but it happens very frequently. It occurs right at the beginning of the tempo adjustment within a song, then doesn’t seem to occur again after that in the same song. I haven’t tested changing the tempo in the software directly to determine whether the issue is specific to using the controller. Could it be due to only having 8 GB of memory or maybe an issue with the controller? Are there any settings I could adjust to help fix this?
Thank you for your help.
