Spotify Library Navigation Issues
Issue: Spotify playlists aren’t staying loaded in the background on IPadOS.
  • Device model: iPad Air 13-inch (M2)
  • Version of operating system: iPadOS 18.6.2
  • Version of djay: 5.6 (iPad)
When I load Spotify playlist, whether or not I load a song, and I leave the library tab to go to any of the others (FX, loops, etc.), when I return to the library, it returns me to my liked songs list. It also resets to its default sorting (newest to oldest). I then have to re-navigate to find my next song in the playlist.
I do not have the same issue on my iPhone 13 mini. When I return to the Spotify library on the iPhone version (also djay 5.6) it retains where I was in the library and my sorting setting (I usually use ‘sort by bpm’ or ‘sort by key’)
I also do not have this issue with any of the other sources in the iPad app (Apple Music, Files, USB Library, etc.)
  • Open app
  • Open sources and select Spotify
  • Select desired playlist
  • Open drop-down sorting menu in playlist and select desired option
  • Load desired song
  • Leave library tab
  • Return to library tab
C) EXPECTED RESULTS:
Once returned to the library tab I would expect it to open to the last playlist I had open, with the same sorting setting I had active (eg. sort by bpm).
D) ACTUAL RESULTS:
  • You will find that the Library has returned to a default playlist (liked songs for me) and default sorting.
  • Repeating these steps on iPhone you’ll find that the library has remained on the playlist and sorting settings you left it on.
Hi @Squidd.Audio, welcome to the Community! I’m on vacation. Please submit an official support request. Thanks!
Hi @Squidd.Audio ,
I also have this problem on iPad!
I noticed this only happens in the “PRO“ mode. When i select the “CLASSIC“ mode this is working fine and it remembers my previous sorting setting and stays in the same folder, as expected.
Is this a bug? Or is the PRO mode not supposed to do that?
Hi @rhodoisland, this is a know issue - our engineering team has identified the problem and is working on a fix which should be included in an upcoming update (likely 5.6.2). Thanks!
Hello everyone, 5.6.2 was released today and should be rolling out to the various apps stores in the next 24-48 hours. Thanks!
